2005 36ft Concept
Dave M (01-11-2022)
With the Bracket they were mounted on the third hole but some customer would raise it up all the because they wanted to get more speed but the problem with that they would loose water pressure. In the middle you will be fine and if you want to rectify just put a long straight bar and measure from the bottom of the cavitation plate to the bottom of the hull if they are even then your motors are at the correct height.
