Make a Marine EFI code tool for less than $1.00 >
Old 04-04-2018, 09:12 AM
  #51
It's not the same plug as an automotive ALDL.
tracetrimble is offline
Old 04-04-2018, 10:01 AM
  #52
the pin out is different but the protocol is the same...
the connector above (posted by the OP) is using pins: A, B, E, F
serial data should be on pin G.
A = GND
B = Diagnostic "test" terminal
E = Malfunction Indicator Lamp (MIL)
F= VDD (+12v)
G = Serial data
speed options depending on age of the ECU should be 160 baud or 8192 baud
H = master/slave
J, K, D, C, = no connects
_____ --- __
F G H J K
__________
E D C B A
__________
KeatonAZ is offline
Old 08-11-2020, 10:35 AM
  #53
Default help
Does anyone know if this will work on a 2005 crusader 5.7 MPI
kellster is offline
Old 08-11-2020, 12:34 PM
  #54
Received 1,969 Likes on 990 Posts
It will not
Griff is offline
kellster (08-11-2020)
Old 06-28-2021, 01:34 PM
  #55
JWR
I had to take the distributor out of my 1993 Crusader 502.Its been replaced and lined up as close as I could get it to the original position but not perfect. From what I read I just have to put a jumper between 2 pins to take the computer offline to adjust the base timing with the distributor. Can someone confirm this and advise which pins they are. Looks like the half paperclip is doing that job in the original post.
JWR is offline
Old 06-28-2021, 01:45 PM
  #56
SB
Received 3,331 Likes on 1,493 Posts
Carbureted or EFI ?
Do you have a timing gun with adjustable timing knob ?
SB is offline
Old 06-28-2021, 01:52 PM
  #57
JWR
EFI . I'm not sure if the timing light has an adjustable timing knob or not. A friend is bringing it. I don't own one myself.
JWR is offline
Old 09-08-2021, 08:01 PM
  #58
Worked like a champ on my 95 502MPI, I couldn't find a led so I uses a digital multimeter in its place and you can just count the times it completes a circuit.
carnutsx2 is offline
Old 05-15-2023, 09:50 PM
  #59
Originally Posted by KachinaShadow
Optional fire extinguisher not included
Watohead1 is offline
Wildfire
7
06-15-2010 04:20 PM
2 Trick Rick
8
11-10-2006 03:50 PM
29KILROY
2
08-25-2005 12:59 PM
LA3
10
05-27-2005 05:19 PM
kmiller
0
08-02-2004 08:57 PM
Quick Reply: Make a Marine EFI code tool for less than $1.00
