smartcraft retrofit
Charter Member #139 /Moderator/Platinum Member
this is a intersting project I have talked to my electrical electronic group abpoout and depenf=ding on what you actually want to do with it would not be that difficult for prob between a $100 and $1000 you can he=get the necessaryu stand alone hardware and a 6-10" c0ommercial color touch screen. If you want this just to monitir and take teh place of all of you analog guaged it the just a matter of writting the code which a can get prtty costly if you cant do your self
The question is is there a maket for this and what could you sell it for?
Kept the Bullet and the condo and joined the cig 20 restoration club.
Smartcraft utilizes the CAN protocol; controller area network. This is a multiplex wiring system widely used in the automotive industry. www.tern.com sell an inexspensive ($100) OEM module that can be programmed in C language. Better yet, I think this wheel has already been invented. The aftermarket automotive industry has this available for gauges, etc. The benefit is ease of wiring, since CAN sends message packets over the network.
Regards,
Mark S.
Regards,
Mark S.
What is your goal? Are you doing it to save space, Wow factor, or functionality.
You may be interested in these guys. I am giving there SeagaugeG12 a real hard look. I wish the screen was color.
http://www.seagauge.com/SeaGaugeG12.htm
Along the same lines Garmin is making this unit which is color.
https://buy.garmin.com/shop/shop.do?cID=162&pID=11625
It says it will accept NMEA 0183 signals which the Seagauge-RM will output. I think this is definetly doable even if not with smartcraft per say and the price actually comes out a lot cheaper then doing all analog gauges for twins.
I agree, I think we can figure this out, Let me know how far you have got with the smartcraft.![Big Grin](/forums/images/smilies/biggrin.gif)
Charter Member #232
Gellner from your post it sounds like you are going with a backwards compatible approach? In other words putting a new motor with new tech. into a boat that has older analog guages?
What I and it sounds like others are interested in is that they would like to use their older motors with the new tech guages and have the features of MPG and depth and so on all died into the GPS and what not.
Jon
Jon
Put your best foot forward!
Jon
Jon
Michael
There is some stuff in the works involving CAN. There is a system being tested right now that will integrate everything and display whatever you want. It has a ton of really cool features which I'm not supposed to discuss...
![Grinser010](/forums/images/smilies/grinser010.gif)
The racepack and : http://www.racepak.com/
Aim dashes/dataloggers will integrate with the Mefi4.
http://www.aimsports.com/
Jeff
Jeff
