TRS Drive Install
Registered User
Hey guys,replacing transom on Cigarette Mistress where it was rotted out.Still have all the original holes in fiberglass for my gimbals and k planes.What is the easiest way to make sure I drill my holes back at the right angle?
1 Post
When I installed my hydraullic steering I used a drill attachement. Not sure what its called but it turns the drill into a mini drill press. It attaches to the chuck of the drill with a shaft into another chuck with a plate on the business end with can adjust to different angles. Sears or a Lowes/Home Depot may have them. If you want I'll send you mine to borrow.
Charter Member #232
You can have a machine shop drill you a hole in a piece of alluminum or steel. That will assure that you drill strait into the transom.
Jon
Jon
Put your best foot forward!
'05 Concept SF23
Bam or Cobra in South Fl should have a Merc drill fixture jig you could rent. I rented a 3/5 Speedmaster jig from Cobra when I did my Black Thunder.
