Throttle Only Button Stuck
Help! I have a Quicksilver 4500 Dual Throttle console mount control box with the round black plastic neutral detent "throttle only" buttons on each handle. When I depress the buttons, one sticks in the neutral only position and the other is sticky at best. How can I rectify this situation? I've WD-40'd the hell out of the inside bushing and the rim of the black button as well. Any help would be appreciated!
Thanks,
Harry
Thanks,
Harry
start looking for a new set up. I had the same problem took it all apart worked again for half the season then worked loose again. things get worn out and don't line up right.
Used zero efforts are everywheree if you look for the right money
