Switchable Exhaust
I have 2 sets of Corsa's with y-pipes, diverters, boots, electrical solenoids and harnesses. I pulled them out of my boat with my old engines (can't use wet exhaust anymore).
Let me know if you're interested, I'm not exactly using them right now, so I'll sell them cheap!
Charter Member#157
Electric all the way!
Air leaks, unless the air is set up that with no pressure they are fully open, when closed you can tell if they slowly open.
Screw type take way to long to close! Especially anoying when you want it closed NOW for the authorities!
I have electric on my Teague tips and they are adaquate.
This Cat is trying to keep up with the Big Dogs
Right now I'm leaning towards Corsa but haven't quite ruled out IMCO.
Let me know how much you're wanting for them...
Charter Member#157
Other than the length of time it takes to close the screw types are there any disadvantages? My boat isn't that loud (small block, wet exhaust), I just want to be a good neighbor around the docks and be able to communicate with skiers in the water.
I just disliked the time delay
As well I guess they did leak out of the pivot point. There is a plastic sleeve that the pins are in, others have commented on the leaking as well
If you live in an area that does not allow switchable, then these stick out in the open and are more easile to see. Same as the Corsa.
I just removed the diverters, plugged the holes and then went with switchable tips from Teague.
Kept the y-pipe intack and basically use it as a sound dampening chamber
![Smilie](/forums/images/smilies/smile.gif)
I saw this but not really looking to "go cheap". I want something reliable and if it costs more, oh well. Going with an unknown would probably cost more in the long run anyway.
Corsa seems to have much of that market, I'm just not crazy about the solenoids sitting there pulling juice all the time. The Hardin system looks similar to what Mercruiser used to use. The downside there is complexity; the pump and all that plumbing looks to be a problem waiting to happen. That leaves me with the IMCO system which I've never seen but I like the idea of a jackscrew setup where they're only drawing juice when moving.
What to do, what to do.....
I'm not a cheap person by any means, but I also hate throwing money at a name brand just because. This particular off brand seems perfectly fine. there really isn't much to any of these systems.
I actually heard good things about them so far. A guy over on donzi.net said they are set up like power antenna motors (very reliable screw drive) and a big benefit is that they are not an open / closed system like corsa. They are set up so you can open / close them as little or as much as you want. so, you can go from full loud to kinda loud to quiet.
You're right; there isn't much to these things. If I could find a manual version with a push/pull cable (like an old manual choke) I'd be all over that. The less to break the better!
Looks like $480 plus another $89 shipping. Similar in design to the IMCO setup if I'm reading it correctly. Odd that they have 2 switches don't you think?
I understand from other people that they can be bought for much less if make them an offer. I think you can get them to knock $100 off the price.
