Need aluminum or plastic fuel tank
Do you remember which brand of expanding foam you used. I found this stuff and it seems like it will do the trick.
http://www.marinefoam.com/polyuretha...ink_type=image
Jim
I might be a little late to this conversation but last summer I pulled my tank out. I had to cut the floor and back seat but left the super structure intact.
I had a custom tank made identical to my original from a manufacturer in Florida for about $1300 and shipped.
I can share my experience with you, I took a lot of pictures through each step in order to post here later.
Let me know what you need and I will be glad to help in any way. and I used a 2 part 2lb.foam but I need to look at the invoice for the name.
Good Luck.
David
Good Luck.
David
Good Luck.
David
Good Luck.
David
jim
Charter Member #232
Make sure you use at leaste a 2 pound foam. I am still looking for a tank myself. I am considering a stainless tank.... Will be more costly but there will be no concern with the Ethenol.... I read some stuff that Ethenol can corrode alluminum as well!!!! The other thing that some one mentioned to me was the use of a bladder tank?
Jon
Jon
Put your best foot forward!
Charter Member #232
As for the foam. I am going to get mine from Composites 1. I have an account with them. I am sure that since I have to buy in bulk that I will have left over. Maybe we can go in on the foam and you can grab the left over. The price that you are showing on that other site seems a bit high to me. Of course last time I purchased the stuff was a few years back so.....
Jon,
I also did some research regarding ethanol and what I read was 10% ethanol by volume is accectable for aluminum tanks but any more then that and you have problems, I have only seen fuel with 10% ethanol being sold so I figured aluminum would be fine. In regards to the foam, I have calculated that I will need 7.5 cu.ft of foam to fill the space around my new tank, how much were you planning to buy and when do you plan to get an updated price?
I decided to go with a local guy to build my tank, he built my jet boat tank a few years back and did a great job! He quoted me a price of $900 for a 131 gallon tank. I called a place in Jersey and they wanted $1150 + $200 to get it shipped to my house.
I can give you his number if interested, It would probably be an hour ride for you!
...Jim
...Jim
Charter Member #232
Hour ride is no problem for me. I am waiting on a quote from a guy in RI now. I guess the question is are they going to get rid of Ethenol OR are they going to start to go with a higher percentage.... That is the scare obviously. The guy in RI that I am waiting on is going to quote me a allum. vs. stainless option.
Jon
Jon
Jon
Jon
I heard rumors it was going away! When do you think you will have a price? I would be interested in what your guy comes in with for a price both alum. and stainless Let me know!
...Jim
Charter Member #232
Ok just got some more info. Stainless is illegal if you use gas. So Stainless is out...
This guy was going to use 3/16ths thick alluminum and would be around 1400. So I guess we would need to compair the thickness and quality of the alluminum that they are using...
