Hatch accuator accelerator help?? >
Old 07-15-2008, 09:38 AM
Were doomed!
Wally's Avatar
Received 1,172 Likes on 587 Posts
thats gonna depend on how big a relay they are using in that setup and what your rams draw for power.....you can put like a 20amp fuse into the feed line for the relays and try hooking up both rams and see if it will work....hopefully the fuse will blow before the relay gets damaged....or you can get all fancy and split those output wires into a 2 way splitter switch and then be able to open one hatch then flip the switch and open the other hatch...and do it in reverse to close.....or just go and either make yourself a set of new relays like i have posted in the diagram and be done with it...hell it would probably cost ya $20/$30 from summitt for their relay setps...
-Wally
Wally is offline
Old 07-15-2008, 01:35 PM
Originally Posted by Wally
you know what would also be nice, is a built in auto-resetting circut breaker on each relay.....it would act as sort of a limit switch....when the ram reaches full open or close the amp draw would momentarily spike and the breaker would open....then reset in a few seconds and be ready for the next go-round....hmmmm
I added a 20amp auto-resetting circuit breaker in place of the fuse...
djl7780 is offline
Old 07-15-2008, 02:41 PM
Were doomed!
Wally's Avatar
Doeas it work the way i was thinking?
I was actually thinking about sepperate circuit breakers for each relay positive leg of the circuit....this way when you reach max lift or close completely...the breaker will pop....but you still have the other side available to work instantly without having toi wait for it to reset itself....
-Wally
Wally is offline
Old 07-15-2008, 02:57 PM
Charter Member #232
Audiofn's Avatar
Originally Posted by gsmith9898
The box that they are wired to now has two sides(one for each actuator). Since one side is not working, can you hook the other ram into the other side? Both together for time being, otr will this overload the single relay?
As wally has said it depends on the load. They do make relays that will do all this in one "box". In other words run 2 rams as they are double relays, even 4, 8,...... kind of under one hood if you will.
Put your best foot forward!
Audiofn is offline
Old 07-15-2008, 03:46 PM
gsmith9898's Avatar
Thats what I'm looking for. Any ideas on where to get one?
gsmith9898 is offline
Old 07-15-2008, 09:36 PM
Charter Member #232
Audiofn's Avatar
I will try and take a look at a place that I get a lot of my electronics from locally. It is called U-Do-It Electronics.... Probably be a few days before I can get back there however...
Jon
Audiofn is offline
Old 07-15-2008, 09:43 PM
gsmith9898's Avatar
Thats cool. Remember two wires coming from the switch and one straight from the battery. I'm leaving this weekend for a quick stop by table rock lake and than on to loto for the thunder on the lake poker run. Just won't raise the hatch much.
Old 07-15-2008, 10:09 PM
Check your thread in the eliminator thread...
QWKRN U is offline
Old 07-27-2008, 05:26 PM
gsmith9898's Avatar
Jon
did you find anything?
Old 05-11-2009, 04:26 PM
http://www.speedwake.com/upload/show...ighlight=hatch[/QUOTE]
I know this is an older thread, but I used the schematic in this link (4th post) to wire my slow a** hatch. I crammed 2 relays inside of a 4"x2"x1" hobby box from radio shack . I stuck it to my firewall, grabbed 12v at the batt switch, grounded off a ground lug and MAN WHAT A DIFFERENCE. I should have done this years ago. And for the $10 it cost to do, it is the cheapest thing I have ever done on the boat....Mike
Michael Garibay is offline
Quick Reply: Hatch accuator accelerator help??
