Gen vi flywheel
Check these out------>
http://www.cpperformance.com/SearchR...CategoryID=437
Pick out the appropriate one you would need, just need to know whether you need internally or externally balanced, block or bellhousing mounted starter, and steel or aluminum.
![Drink](/forums/images/smilies/drink.gif)
Cay,
I dont have the part number here at home, but the flywheel for a 1999 Chevy truck 454 should be the correct one. I do have the correct part number at the shop, but usually do not go online during the day due to a dismal dialup connection. Feel free to call me in the morning and I can give you the correct GM part number. 301-843-5700
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
Cast crank this is the fylwheel you need see the link get the part number and call or go to the gm dealer and order it http://www.perfprotech.com/store/pro...169,25622.aspx
![Talking](/forums/images/icons/icon10.gif)
here's more information
Part # Dia" Clutch Dia" Teeth Application
14085720 12 3/4 10.4" 153 65-69 Mark IV, Lightwweight (15 lbs), nodular iron, two-piece seal, internally balanced.
3963537 12 3/4 10.4" 153 70-90 Mark IV external balance 454, 15 lbs
3991469 14" 11" 168 66-69 Mark IV internal balance 454
3993827 14" 11" 168 70-90 Mark IV external balance 454
14096987 14" 11" 168 91-up Gen. V/IV external balance with 4" stroke forged steel crank, 454, 502
10101169 14" 11" 168 91-up Gen. V/IV external balance with 4" stroke cast nodular iron crank, 454, 502
http://www.stingray.nu/se/index.htm?/tips/flyflex.htm
Thanks guys this the gm part no. right, how can i get the casting no. for this? (10101169 14" 11" 168 91-up Gen. V/IV external balance with 4" stroke cast nodular iron crank, 454, 502)
GUSTAV IS HERE IN THE CAYMAN ISLAND CAT 2 NOW!
ddabal
Do It Yourself, Boating on a Budget
5
07-08-2008 01:40 PM
cooltoys61
10
09-07-2004 11:33 PM
