Installing K-Planes
Get this for drilling the holes straight.....its cheap, it works,
https://www.harborfreight.com/angle-...ide-95622.html
Were doomed!
If you happen to have autocad i can send you the file i made when i was installing my k-planes...if not i can convert it to a PDF in full size but i'm sure you will have to go to Kinkos or the like to be able to print it out in one sheet...
-Wally
-Wally
Ron, with all due respect you are over thinking this. Drilling 90 degree holes is pretty straight forward. What you do need to do is drill them 1/8" plus oversize and line them with an epoxy glass tube to completely waterproof the holes. Don't expect sealant to protect your transom with just 1/2" holes for the bolts. Do the same for the hydraulic fittings.
Make your own template and use it to drill the holes in a scrap piece of wood, preferably as thick as your transom. That way you can test fit and make corrections to your template/drilling technique before risking any crooked off-center holes in your boat.
I did what ren3 mentioned when I installed ext steering. Great idea. Also used Brad Point drill bits after drilling the 1/8" pilot holes. Much more accurate and they cut nice clean holes thru wood and epoxy. Started with a 1/2" elec drill but switched to my 3/8 cordless drill after tweaking my wrists a couple of times.
In regards to drilling straight, I used the situation as an excuse to buy that drill press I always wanted :-) Picked up a couple of samples from the "cut-offs" barrel at the local metal shop and made 1" thick alum drill guides. My transom fittings used pre-drilled backup plates on the inside so I didn't have a lot of wiggle room. Turned out great.
Can I get the DWG for this? mgray(numerals seven five seven)(at)pm(period)me
Padraig (12-21-2021)
Were doomed!
Ill send it out on Monday...i left the USB its on at work.
-Wally
-Wally
Were doomed!
Just sent it....let me know if it comes through ok.
-Wally
-Wally
