fuel issue
RIPSTA Racing Team
Disconnect the line from the tank to the pump. Blow air into the line ane listen for bubbling. Make sure you have hooked up the line from the tank to the correct side of the pump. I don't think its possible to mount it below the tank level since most tanks are at low hull level. Shouldn't matter, pump should have some draft/pull ability. Check pump out line to engine to make sure pump is good. Even new pumps come bad right out of the box. Now that everything is made in Japan or Mexico who checks for quality?
Originally Posted by [email protected]
put a new electric fuel pump on a cant seem to get any fuel out of the tank, i dont no what the problem is. anbody ever had this issue.
87cafe
thanks for all you guys help i will let you no what the out come is, rea son for changing the pump was no fuel was being deliverd to the carb, and my fuel pressure guage wasnt showing any pressure. one more question i have mechanical and electric why both? and yes you could hear my old pump it was still workin, so its aparent its somethin else.
