Stroking a Reverse Rotation 454 >
Old 04-23-2011, 12:40 PM
  #41
Steve 1's Avatar
We always ran reverse rotation motors on the cats with arneson drives,I have dyno'ed a bunch of them,The Hp was right there with the standard rotation or a little higher.
Steve 1 is offline
Old 04-24-2011, 10:44 AM
  #42
Looks like you are on the right track, Bob will set you up with a couple of torqe monsters.
I use the AC Rapid fire #1's. As far as a oil cooler, I use the EMI 3" combo cooler, you will need big ones with all the weight of the boat. Most guys are using a 750-850 CFM carb on a engine like yours. If you do not have wideband O2 on your boat getting it dyno'd would probably save you some headaches. They could jet it for you and get your mix correct. I have a Holley MPI kit and I tune mine on the fly with my laptop.
jeffswav is offline
Old 04-24-2011, 10:52 AM
  #43
Contact the link to Mr. Cool. They are very helpful. They will give you accurate info about your cooler needs.
Boat1 is offline
Old 04-26-2011, 09:36 PM
  #44
Thanks for the reply. I still dont have the carbs figured out but I did get 2 DUI Ignition systems for the project.
fastestonehere is offline
Old 04-27-2011, 09:40 AM
  #45
They work well, I have the Marine version with computer controlled timing. I have run it two full seasons and no corrosion or rust.
jeffswav is offline
Old 04-27-2011, 08:36 PM
  #46
Heads are in. Thought I would share
Attached Thumbnails Stroking a Reverse Rotation 454-afr-forum.jpg   Stroking a Reverse Rotation 454-afr-top-forum.jpg
Old 04-28-2011, 06:49 AM
  #47
very nice....way overkill for your project in my opinion..
ezstriper is offline
Old 04-28-2011, 08:29 PM
  #48
Which ones are they, they look like AFR's.
jeffswav is offline
Old 04-28-2011, 09:11 PM
  #49
Yes Sir AFR 264's stamped 265, 155# spring seat.
I talked with Bob M. He says I should have cams this Wednesday....
Old 04-28-2011, 09:12 PM
  #50
Why do you say this!
