Crankshaft Pulley Gen 5 v-belt to Gen 6
Working on re-powering my boat... Putting all the GEN 5 v-belt setup on GEN 6 BBC. Is there an issue will the pulleys lining up? Do you have to shim out the other accessories to match? Any advice is much appreciated. I'm not sure i need to by new pulley/balancer.
Shouldn't be.......Early Gen 6 motors like mine came with the V-belt setup.
All the pulleys will bolt up. The Alt, PS Pump, Sea Water Pump have to be drilled out for the bigger bolt size on Gen 6 heads. There is nothing to it. I mounted all my Mark IV on brand new Gen 6 engines. Just takes some time.
