Fuel in fuel pump oil?
my boat was cutting out last weekend at load, idled fine and fine easy off idle. It cut out trying to get on plane a couple of times, not every time. I was assuming seeing the fuel in there that the pump was bad causing my issue.
How do I tell if the pump is bad? If it was wouldnt this be a consistent problem at load not just sometimes?
