Port e-top header exhaust boot burnt through twice
I have 4 hrs on my new 540 efi, two weeks ago I found black on my white swim platform that is directly below my port exhaust tip. I pulled the plugs thinking it was running rich, but plugs looked perfect. Went back to the water only to immediately burn through the boot between the header and tip. I brought it home, pulled the Outdrive and put a new seal kit in after finding a damaged o ring. I ran the boat for 20 min around table rock lake and burnt through another boot. I have back flushed every hose and cooler on the cooling system, and checked the veins on the sea pump only to find nothing. I tried tightening my serpentine belt, and took the boat out. Upon startup the port side starts shooting water out about 3 sec later than starboard, but have the same amount of flow at idle. With the boat on plane for a cpl mi, port side flow is next to nothing, and the tailpipe reads 50deg hotter than starboard. The bottom water rails on the headers are plumbed to the thermostat housing w 1" hose, the thermostat has a 140deg with 3-1/8" holes in it. The thermostat housing's two ports set 90deg apart, and also has two temp probes in it. The motor always runs at 150deg. I am obviously overlooking something, but still don't understand why I'm running out of water on the port side while I'm cruising.
i have a 496 mag ho in my boat. The previous owner installed a ball valve just before the starboard side water rail to the header. It helps redirect flow to the port side headerby closing it very slightly. Sitting at idle i can actually feel the difference in temp on the tops of the headers with the valve wide open to the valve being slightly closed on the port side header.
