EMI Thunder alternator mounting
Registered User
i guess your talking about a 454/502 base gm engine???the only hicup i ever had w/emi manafolds was the power steering hose on the high side i had to use a special bango fitting to clear the manafold.are the manafolds touching the alternator?where?top/bottom?
This is on a sbc 5.7 Merc. I had the old log exhaust and the brackets bolted to the front of them.The EMI's do not have any provisions for mounting. I will have to come up with some kind of bracket,
1 Post
fixx
http://www.cfrperformance.com/1955_6..._p/hz-7758.htm
this is what i have on my donzi,,for the 21.00 you cant make anything work! ...dont mind the year,,it will fit as long as you dont have a power steering alt combo bracket..i use a goodyear 13290 belt..if you use a 15290 it will come off at high rpm's..the 13 series is a little skinnier and sits deeper in the groove..
I have the power steering bracket, but it is a power steering only bracket. If I had the combo bracket, that would work also, but they want a grip for a used one on ebay and alot for a new one.
1 Post
fixx
I do like that bracket.Will this bracket work with the stock merc crank pulley in the original groove?
