hp525 gauges lock up
Hey guys wondering if you can help me. when I start the boat all gauges work great when I start driving for a while they all lock up except spedo. Has this happen to anyone before?
its a 2007 hp 525 with ex pkg on a 28 nordic heat
great explanation, you should get some super replies real soon pffft!!
You have a digital to analog converter on that boat. The engine uses the 14 pin connector so a converter must be installed to operate the analog gauges. My bet is the converter is messing up, or you've got a bad connection. They are not too expensive. First check connections, then just replace the converter.
Bob Lloyd
Bob Lloyd
[QUOTE=bobl;3864744]You have a digital to analog converter on that boat. The engine uses the 14 pin connector so a converter must be installed to operate the analog gauges. My bet is the converter is messing up, or you've got a bad connection. They are not too expensive. First check connections, then just replace the converter.
Bob Lloyd[/QUOT
Thanks bud, I will check it as soon as I can and let you know how it goes
Bob Lloyd[/QUOT
