any one running locked timing ?
any one running fixed timing how do you like it.. Ive ran it in the past on some small blocks considering running it like that on my low compression 454,s
I run my procharged setup locked @ 28...helps low speed...now going to megasquirt and EFI so can control timing at whatever RPM I want...will run even more at low speed and back it off as the RPM's and boost come up...
I now use MSD6 Programable. The unit is a pain in the azz to figure out and MSD tech line is less than sympathetic and even less helpful. However once you get the plotting figured out you can adjust the timing 25 degrees. Can can add or retard timing electronically with a lap top and it has built in rev limits etc..
I'm locked at 34 on my well built 524 at 10:1 compression. I was concerned about eating starters, I crank it before I goose the throttle. It idles and performs significantly better. I've tried limiting advance to 10 degrees total advance with custom bushings to get more timing at idle and I've also tried MSD start retard boxes. Both were a waste, no problems under extreme loads either. I was trying a bigger prop when my wife decided to plan a family outing on the lake, 8 adults and coolers and no problems in late August heat.
