502 mag ecu relocate
I am putting on headers and wondering if anyone has ever relocated the ecu/bravo drive oil reservoir on a gen 6 502 mag? I am thinking the reservoir may need to be high (where it is) for gravity to do it's thing. And wondering of the ecu has cables running that don't have enough length to reroute somewhere else? I think it would be cleaner if it was moved, but could just give in and have brackets welded on my headers. I wanted to see of anyone else had tried it before I go unwrapping cable wraps to see.
Another idea was a bracket to mount the ecu off of the engine somewhere where it is instead of off the header.
Thx
Larry
Thx
Larry
I would get the bracket welded to the header for the ECM. That is how mine is on my CMI's.
It does not look like any extra length in the wiring harness with certain wires going one direction and other wires going another direction.
I would mount the drive lube bottle on the transom.
If you don't mind dealing with the harness ,you can mount it under your bow light if you want. I'm obviously being sarcastic. But the wiring to ecm is the issue
