formula dash upgrade
Is it just me or does the CF trim around the tach and speedo look like a bathing suit holding up some Big Fat Titties .. I like Titties...lol... Looks Good
Chris
Chris
Thanks for all the kind words. I am very happy with the way it turned out. I have a few things to work out, the first is the water psi guage is not reading any psi. I'm hoping its just a zip tie that is a little too tight although I was very careful with the install. I also have to check the wiring on the wiper switch. I have a on off on switch installed, with the switch up the drivers side wipes but with the switch down only the passenger motor wipes so I think I need to install a jumper wire to make both sides wipe in the down position. After I work out these few bugs I have to learn how to use the chartplotter.
