Dry Joint Manifold Riser Conversion
Is it possible to convert to dry joint from old style wet joint risers/manifolds on a 1998 mercruiser 5.0. If so what parts are needed?
Chris
Chris
To be clear, I am replacing manifolds and risers. looks lije just a few hoses to go to dry joint. anyone ever done this?
Chris
Chris
That's kind of what I was thinking. I have the stainless cast risers from Merc, and they have a nipple on the front side of them for a jumper hose... Looks like you could run 'em either way, as the still have the 4 slots at the mating surface. For the dry joint, I believe you need a stainless plate with only the exhaust opening, and then double up the gaskets to either side.
CC230 you should have been Just Sayin 2 wks ago...lol... I have completed the conversion. How do you like the 6.2 Thinking of building a 383 next year.
Chris
Chris
I bought those from an OSO member as a package with the 6.2 heads, I'm building a 383 and ended up having to use aftermarket exhaust. Marine Kinetics cam wouldn't work with them. Hoping to get it assembled and get working on the boat soon.
