Hatch lift
Only the Best Will Do!
http://www.keitheickert.com/c-40-hat...-and-rams.aspx
We sell electric hatch rams and hydraulic. PM me for details OP.
http://www.keitheickert.com/p-13440-...tor-relay.aspx
If you're annoyed by the slow speed that your hatch actuator has and you would like to make it work faster, then this is the answer. By transferring the electric load from your dash accessories to the accelerator box, the total voltage to the hatch actuator is greatly increased, thus accelerating the hatch opening and closing.
if you had a fire opening it fast could be the worst thing you could do adding all that air....... just somthing to think about
With all due respect this is a perfect example of how a marine supplier is marking up the identical part a ton more than is required to make a fair profit. The exact same actuators are available for other industries for half of what Keith Eckhart is charging
All because of the word "Marine"
Makes me wonder if there is a patent on the Dana/ CP hydraulic hatch lifts. You can not tell me that the hydraulic rams, aluminum hinges and wiring cost that much, I am really tempted to produce my own and sell at 5-15% mark up and bet at that cost they would only be 400-600 aft material, labor and shipping
Patent? Its basically a billet hood hinge with a small hydraulic cylinder. Price comes down to time and volume. I takes so much time to make/source all the pieces parts. Time is money. to go beyond recouping that money and make a profit that expense has to be added to each part. If you make and sell 20 units, that time /money will significantly impact the sales prices. If your doing 20.000 of them the impact is negligible.
