Dyno time versus Engine stand >
Old 04-20-2014, 06:15 PM
1000 around here
Originally Posted by ICDEDPPL
The $500 for a dyno session is worth every penny. 3 hours on the water + gas running back and forth or 30 minutes at a dyno. Plus you get to find all the leaks instead of a murder scene the first time you take it out.
When someone asks how many ponies (every stop) you have an answer instead of a guessing game.
stimleck is offline
Old 04-20-2014, 06:38 PM
Where are you located? Maybe someone on here could shed some light on a shop that dynos that you weren't aware of. 500$ is the going rate here also. Especially an engine that is relatively mild (no huffer, ect)
Might be worth asking around. And yes I agree with what's said above, the money spent will be well worth it. You'll know exactly what you have and that it runs as it should.
mickeymcclgn is offline
Old 04-20-2014, 07:08 PM
SB
Received 3,166 Likes on 1,430 Posts
Originally Posted by stimleck
I wish I lived near a couple of the guys on this board like Mild Thunder or Mike Tkach! when I walk in to the dyno shop they will see me coming lol
Be careful what you wish for.
You'd then want superchargers, intercoolers, and bigger drives too.
SB is offline
Old 04-20-2014, 07:13 PM
SB
Run it on a stand to make sure timing is all set, no water/fuel/ oil leaks...then if you are uncomfortable with your tuning abilit and/or want to save money by zeroing in on prop choice needed...bring it to a dyno.
Nothing worse and more expensive then putting a motor on a dyno that has some sort of problem like leaks or etc that requires time or tear down.
Where are you located ? Maybe someone knows of a good dyno shop that will help tune and not charge you a ton.
Edit in: Be forewarned, some dyno shops will get you a power # that's not correct and won't help you tune...which turns into a big waste of money.
SB is offline
Old 04-20-2014, 08:01 PM
Located near toronto
stimleck is offline
Old 04-20-2014, 08:09 PM
SB
Oh. I'm out. I don't even know if $1k Canadian is a lot or not. LOL.
SB is offline
Old 04-20-2014, 08:20 PM
If a rebuilt engine is set up on a stand is there much difference than being run on a dyno?
can you do all the same tuning on the stand?
Dyno time around here is very expensive but run on an engine stand is much cheaper
if by rebuilt you mean a refresh like bore job with same compression pistons,same cam,valve job ,rings&bearings,timing set than a run stand will probibally do the job but if compression ratio,cam or heads,induction system were changed a dyno is a good tool to help sorting the tune.just my humble opinion.
mike tkach is online now
Old 04-20-2014, 08:30 PM
New pistons bore 30 over new cam new bearings nw valves and springs
stimleck is offline
Old 04-20-2014, 08:31 PM
LMAO 1000 canadian is like 1150 usd
stimleck is offline
Old 04-20-2014, 09:04 PM
Rookie's Avatar
Received 1,249 Likes on 604 Posts
So how much more power is made at an AFR of 12.8 on a dyno compared to an AFR of 12.8 in a boat if same exhaust/setup is used?
Just curious
Rookie is offline
