power steering valve; which fitting is hi pressure, which is low? >
Old 05-03-2014, 10:44 AM
Default power steering valve; which fitting is hi pressure, which is low?
2000 bravo setup. bought boat with empty engine compartment, cut off hoses at valve. have tons of 80's stuff laying around. on the old stuff, small fitting is pressure and large is return. this newer one, fittings are close to the same size. i figured i should be sure which is which before i scare up adapters and hook it up backwards. thanks. and does anybody know names-sizes of the fittings?
dereknkathy is offline
