Engine Coolant in Bilge after Winter
Looking for some help. I have a 2003 496 Mag with closed water cooling. Just got it out of storage and the Coolant Reservoir is empty and all the coolant is in the bilge. I just filled itback up with coolant and put 17psi of pressure on it for 1/2 hour and no leaks or drop in pressure. Everything seems good. Any ideas where I should check? Thanks, Vonny
Forum Regulator
Welcome to the site.
Probably grommet 14 in this picture.
http://www.boats.net/parts/search/Me...TEM/parts.html
Feel free to use the OSO search function. There are at least 12 threads on this very topic; like this one:
http://www.offshoreonly.com/forums/g...ant-bilge.html
Also, if you are still running the original antifreeze, you do not know it's age, or if it is starting to turn dark/metallic in color vs. pink; it's time to flush and replace. It's only good for 6-7 seasons/years tops; less with high use.
Thanks Brian and Sydwayz. I can tell that it was leaking around the grommet. I will get replaced before next storage time. This site is great because of members like yourselves! Thanks Again!
Forum Regulator
You will want to replace it now before the season. If it's leaking while sitting, it's DEFINITELY going to leak under pressure while running.
