500EFI Trying to Install Livorsi BIllet Controls - Throw not long enough HELP!
Hello all,
I am trying to replace my old Merc Zero Effort controls with some shiny new Livorsi BIllet Controls on my Merc 500EFI motors.
The issue is that i cannot get the throttles adjusted so that the butterflys on the throttle body will open all the way to the 'stop' on the throttle body (or at least close). When the throttle is pushed forward as far as it will go (i have the stops on the throttles adjusted all the way 'in') the butterfly of the throttle body is about 10 degrees off of horizontal. I have also adjusted it so that when the throttles are pulled all the way back, the throttle body just barely touches the idle stop. It seems like even though i have the 'pin' for the throttle cable in the longest throw travel position, there is not enough travel in the new Livorsi throttle assembly to allow me to move the throttle body butterfly from idle all the way to full open. It doesnt seem to matter how much i thread the clevis's on either end of the cable in/out, that will not change the amount of travel that the throttle assembly gives me, which is my main problem.
I called LIvorsi and they had no solution to offer, which i was shocked at! I have called them several times to no avail.
I was wondering if there might be an alternate throttle body linkage assembly that would allow for a smaller travel to move the butterfly fully open/closed.
Could someone point me in the right direction please?
I went thru this this spring, went from zero effort to livorsi. I had the same frustrations... when I had my motor on the dyno, Haxby told me that from his experience the last small percentage won't skew the power.
Seems to be true in my set up anyway.
Good luck-
Good luck-
JB Marshall
I would also post this in the Formula section, others there may have experience with this. I hope to learn from this as well, I am planning the same upgrade.
Or better yet, an even more common shifter !
Especially for what they charge for them. You have the pins for the cables at the controls on the lowest mount point on the controls, correct? Not the mid or uppers? The lowers should give you the most throw. The threaded part on the engine side won't help with the throw like you found out. That's more for taking the slop out.
I went round and round and round with this, if you try to get it perfect for WOT your idle stuff will start to be an issue. (depending on set up) Doesn't take much "extra" air to affect your idle, IAC, shifting, all that. Mine needs to be closed TIGHT at idle. (or it idles at 1200)
Good luck.
Good luck.
Thanks for all of the responses.
Yes I have the pin at the hole in the control that gives the most throw. I don't know if there is another hole in the linkage at the throttle body or if there is the opportunity to drill a new one. Will look this weekend.
I wish I would have looked at the butterfly position when I had the old control in. I don't know if the old control had the same restriction or not.
I have not run it yet so I don't yet know the impact on performance at WOT, so maybe Launchpad is right that it wont affect performance. I will post again after this weekend to let all those that are curious know how It went. I will also try to post some pics.
