Best aluminum heads out there??
#101
JoMar Performance makes stud girdles for just about everyone. I think they even make them for AFR. I've been to their shop and they have Dart and AFR heads everywhere. Their price is better as well. I have a set of their stud girdles on my AFRs and you can tell they are made for them by the close fit. If you use the wrong girdles you will screw up your geometry big time as the AFR heads changed the valve angles.
#103
Have someone run a Pipemax on you motor and find out what length intake runner the motor wants. Then select an intake. They all have different length runners. That's the best way for maximum power.
#104
bob sent the specs to a company named webster industries and they make them for him.they are a very nice fitting part.
#105
get the head that matches best for your 502 then when you build a 540. send them out and have them gone through and ported. win win. you get the best heads for both engines and they are fresh both times for less money than two sets.
#110
