Best aluminum heads out there??
#81
there's 2 types of hard anodizing,,1 like afr does and the mil spec hard anodizing canfield heads were done in.
I have a couple of places close by us that does the mil spec hard anodizing.they told me everything need to be removed before they'd put the pieces in their tank.
when done mil spec,,surface is hard to scratch.afr's h.a. comes off w/ a lite touch of a sand paper roll.
#82
MarineKinetics
The AFR hard anodizing is applied to the casting pre-machining,There is no masking or post application prep. They are ready to run as delivered. The up-charge on the heads is $175.00.
#84
http://www.boatingmag.com/how-to/cho...rificial-anode
#85
We didn't flow them before porting.
Pretty sure he opens them to .700.
I'll check the sheet when I see the machinist tomorrow.
Maybe I'm goofed up on the exhaust flow as that does seem high.
According to the brodix site they flow 340 and 240 "as cast".
A local old timer that's been at this for longer than I've been alive does my stuff. He used to do quite a bit of work for the local shops before CNC came around.
I'll report back as I certainly don't want to give bogus info.
*edit* 313 not 330 on the exhaust. Also, 2.30 intake valve instead of the 2.25 the heads come with.
#87
I havent heard anything on here about the semi hemi heads from goodwin, does anyone have experience?
they are listed for $2100 assembled?
http://www.goodwincompetition.com/cylinder-heads/
#88
#90
All I saw was brodix heads for $4,000 cnc complete?
