ignition curves for turbo engines
you are not running any kind of intercoolers right ? without those I still would lock dist and run 34 and pull back to about 26 under boost, or if not boost retard try 26-28 locked. We run a blowthru set up with intercooler and are at 34 locked, no retard, but without intercoolers or E85 ???
Take it from me (the previous owner that put all that stuff on) you need more initial advance. I agree with GPM. You're going to need initial of 14 I bet because of the poor volumetric efficiency at low rpm. Bump it 2 degrees at a time until you get your good starts then set your total advance accordingly with our bushings.
Carson's the man!!!
Talked to Carson. He said lock it at 30 degrees. My starters have no problem spinning the engine because I have such low compression. The engine starts better now and idles cleaner too,
I figured as much.
You know, going from number 2 Speedmasters to TRS's (1.33 to 1.5) means you just gained 600RPM so I bet at the end of the day those 21 clevers will be history and you'll have 25's Mirage or Hydromotives on that Scarab.
