iboats does not have MEFI expert and I have a known issue.
Is it me or what in the world 2004 GXI Volvo Penta engine do you have 5.0 or 5.7 or the 8.1
the 8.1 uses different fuel pressures than the small blocks the fuel pressure low and high is different spec between the 2.
What do you have and I can tell you what your fuel pressure should.
I might have missed what engine you have so If I did sorry but If not I do not know how anyone can even give you correct answers because a 5.7 does not have or use the same ignition nor reads the sensors the same compared to a 8.1. food for thought.
I clearly do not see what GXI engine you have. how can anyone answer or reply to what your problem is ?
496 is a totally different animal that the 350 especially for any diagnostic testing along with fuel pressures are not even close to same.
21608511 is the current part number cool fuel cell thru Volvo it lists for 929 so I take it you bought on line ebay thru Lenders for the 600 bucks. There is a little story about these online.
To clarify I'm not getting a fault anymore. But, I haven't exceeded 3000 rpms since this problem showed up.
My point well taken I hope - Like I said in POST 2 "before we even get started" "Engine model #" needed -
how can anyone with no eyes - no hands and no ears and the BIG ONE not knowing what you have throw any answers out to help fix what ? Heck you could have a 4.3 GXI Volvo for all what was not known.
Anyways simple as running the boat out of gas can throw a cam and crank sensor code on a 8.1.and even the engine misfiring for the 8.1 can do the samething. Just saying .
Volvo manuals at one time had the fuel pressure specs wrong Yours looks like it has the correct ones. I will throw them out anyways.
fuel pressure specs are.
Low pressure 8 psi + or - 4 psi
High pressure 40 psi + or - 4 psi
and needs to be steady fuel pressure.
Buying the online Volvo cool fuels can be a problem because Volvo found out afterwards some would leak. So just recently all cool fuel systems were on back order and the online cheapo ones got stuck with some of the bad ones.
Now I am not saying you have a bad one but all the ones that were online are gone now and some for reason - They leaked so it could be a 50 / 50 chance that anyone got a bad one from buying online. You roll the dice with online parts and most come with no warranty either. Just saying.
Again you still could have a good fuel cell but I am telling the true story about them in the past 3 months to current. Volvo has them back out now for the good ones and the current back order has been lifted. FWIW.
My point well taken I hope - how can anyone with no eyes - no hands and no ears and the BIG ONE not knowing what you have throw any answers out to help fix what ? Heck you could have even a 4.3 GXI Volvo.
Anyways simple as running the boat out of gas can throw a cam and cranks sensor code on a 8.1.and even the engine misfiring for the 8.1 can do the samething. Just saying .
Volvo manuals at ne time had the fuel pressure specs wrong Yours looks like it has the correct ones. I will throw them out anyways.
Now I am not saying you have a bad one but all the ones that were online are gone now and some for reason - They leaked so it could be a 50 / 50 chance that anyone got a bad one from buying online. You roll the dice with online parts as no warranty either. Just saying. Again you still could have a good fuel cell but that's the true story about them in the past 3 months to current. Volvo has them back out now for the good ones. FWIW.
Does anyone have any insight in regard to this "know issue" i was referred over for? If it was just simply the fuel pump issue then thats not anything I didn't already know. I was hoping it was something less obvious. Also, can anyone touch on the power balance test?
what "know issue" can you explain all the issues you are having ?
I will look at this later have to go back to work
Has any OEM Volvo dealers looked at your issues / engine as I am asking because it seems that you have been trying to resolve these for a while now ?
My instinct is since my problem started when I rebuilt/replaced the fuel pump i'm chasing a lean condition. But, I'm by no means an expert, just a driveway mechanic that doesn't want to drain my bank account (and subsequently listen to my wife lecture me) to have someone troubleshoot at $100+ an hour.
Power balance I just gave out the jist of it. Post 9 but make sure you read post 14 in the link below. I would read post 7 to.
I made a mistake called it power balancing test but really is called power balance test.
http://www.offshoreonly.com/forums/g...n-hp-500s.html
I have NOT been on iboats so I guess it is a compliment that my name comes up as a referral.
Can you tell me what sensor(s) you have changed out with new if any ?
Have you examine your spark plugs ?.
Does your scan show 100 % available power while the engine running ?
Ok now I have to get some stuff done - I will read all of your posts later and see what comes to mind.
the jist - just off the top of my head and just saying - fuel injectors ??? and or crank sensor ? If you do not have 100 % available power then possible bad coil(s) or an internal engine problem.
Do you have closed cooling with your 8.1 Volvo come either way ? was your engine winterized properly ? .
