bouncing tach
bouncing tach
Hi All. Recently had my panel apart to troubleshoot my nav lights and blower not working. A bit of poking around and that problem was resolved, but afterwards the port motor's tachometer started bouncing around while cold. This issue occurs for the first 5 or 10 minutes running and then it settles down to normal. I dont even know where to begin, any advice from the old salts out there?
https://www.youtube.com/watch?v=oP162dC2eGw
Jump behind tach, make sure connections are good and also tight.
Also, you'll see a small switch you can turn for amount of cylinders - turn that back and forth a few times and put back to 8cyl.
pole setting on the back of Tachs needs to be moved and put back in the same spot or a hair off.
http://www.pontoonboatforum.com/uplo..._setting_1.JPG
I hear that but if your kitchen sink in your house is leaking do buy a whole new Kitchen with counter tops and all or just try to fix the leak at first to see what happens ? just saying
Thanks everybody for the suggestions. Hopefully i'll be able to look further at the problem on friday and i'll check these all out.
A couple more relevant points:
-I actually had the panel off a couple times before i resolved the blower & nav lights issue. The first time i put it back together I'm almost certain that it was the right tach that was jumping. After the second time i had it apart (and by then the blower & nav lights were working) the bouncing tach had migrated over to the port side, with the right tach being rock solid. I've gone out 3 or 4 times since then and the problem is now not changing, not getting better or worse.
-Whatever causes the issue, it totally disappears within 5 or 10 minutes and doesnt recur until the motors have fully cooled down again (e.g. it won't happen after a 4 hour rest on the beach, but will after letting her sleep overnight).
Those facts make me doubt its a switch issue on the backside of the tach... but i will definitely check that out and report back here.
SB I was trying to be funny about it as I said could be a bad tach to. And for the leak in the sink you are right guys will try many of times with Teflon tape and the women would go for - its time to get a whole new kitchen, sink included.
