Engine questions 500
You guys are just running the wrong stuff. Im running a special set of matched unbreakium rockers using a proprietary unobtainium alloy for the roller bearings. I have a friend who was a rocket scientist for Nasa and he hooked me up.
yea that new alloy pro comp uses is the BOMB,lol.
Are those specially staggered so you can pass him on the outside in turn 4?
Seriously though, thanks for the help on this one.
I don't think the "cycle life" thing is that cut and dry. Theres guys out there running crane gold rocker arms in boat engines that have been thru quite a few hours. I changed mine out in 2010, and they were stamped from 1985. They had lots of time on them. out of 32 Rocker arms, 1 had a cracked Trunnion. What gave up, wasnt the aluminum body, but it was the steel part of the rocker arm!
Mercury used those crane gold aluminum rockers on everything from the old 370hp 454's, to 420's, HP500s, 500EFI's, 600sc's, 800sc's, 575sci's, 525efis, 525sc's, and so on. Granted those were not extreme engines, and none of them were running big spring pressures or extreme cylinder pressures.
I'd be willing to bet, take that rocker arm that goes 700 hours on a 420hp merc, and stick it on a blown engine making 2hp per ci, lots of spring pressure, and the exhaust rocker has to open the valve against extreme cyl pressure, and its not going to go nearly 700 hours. Throw in a jerky cam, and it might go 50 hours before eating chit.
on my friends 1075s in a big OL,were just a little past that on hours.so far,185hrsish and we plan on another 75 this summer.I check them and the lash every 25.lash hasn't moved all that much.
