overhead crane
Cm Cyclone arrived, as advertised, unused, laying around, named scratched up.
Checked the entire Hoistaloy load chain for signs of damage, use/abuse. None found. Checked random links for stretch, none found. Slight surface rust on load chain. Load chain hook is unused.
Endless chain has some light surface rust.
Checked the case for cracks, none found, checked machine screws for signs of tampering, none found. Checked top hook, no use.
I like this hoist, let's help it out a little.
Did you give any thoughts in using a rolling trolley on the top cross rail to attach the hoist in lieu of a fixed positions tab ? It would make alignments (right to left) a little easier if/when needed.
i do believe when ed pushed the up button on that cm cyclone he rode it all the way up to heaven!we lost a good man.
