Another issue for the brain trust..
#31
Battery was in trunk, and ignition box behind glove box. Wires ran under carpet. Cap needed a little pressure to short a wire. No pressure, no short !
No issues when back to the shop because there would be no passenger !
Fuk !!!!!!!!!!!!!!!!!
#32
Problem solved. I always preach to the guys here to check the simple stuff first. Always check fuses etc. first, then after the easy likely stuff checks out, then the complicated conpiracy theories.
Well, I bamboozled myself.. The #2 and #4 plug wires were crossed. I'm too happy to be embarrassed. Both sides are peppy and healthy now.
Thank you all for your time! Sorry it was something stupid. Thank you Jim for pointing out the obvious.
#33
#34
I'v replaced probably more ignition wires than 95% of the people here, and I still use these at the distributor when I have them, not to just make it easier for me, but the next guy (owner included) also.
![](http://static.summitracing.com/global/images/prod/xlarge/MRG-4472_xl.jpg)
#35
Always remember: "18436572" LOL. My Dr is a Car guy and has restored a few Camaro's and Corvettes. He did my last surgery and when I was just coming around after general anesthesia after surgery he asked me " OK John...firing order Chevy V-8?"...My answer...18436572...He said..".ok...He's ok...turn him loose in about 30 minutes !!!" LOL
My new BBC has a double swap firing order... "1-8-7-2-6-5-4-3"
REALLY messing me up.. LOL
#36
Guess who's going to the river this afternoon?
I just love the sound of these things. Music to my ears...
https://youtu.be/6blqc3QndwU
#37
Jim
#38
when engine is dressed and marinized it would appear all the plug wire lengths etc could never get switched around but with a little trouble shooting here and there wires can get pulled and the next thing you know you have two or even three the same length dangling in the bilge. I always make a habit of following from and to but these are time savers.
#39
She was running good. I was real happy with it. I am still running 22 pitch props. I have some 25 pitch I just bought but the hub adapter is different so I can't run them yet. I spun the Rt motor up to 5700 rpm which was apparently more than it wanted. I checked my guages and noticed the oil pressure was low on the Rt side. Killed motor. Opened hatches. Rear seal apparently let go. Oil everywhere on the back of the motor. Limped back on lt side. Got back to shop. Put oil in Rt side. It was 2 quarts low. Fired it up. No oil pressure. Killed it. That's where I am right now. Supposed to carry family to gulf shores in a few weeks. I'll be pulling the motor, cutting the oil filter open and going from there. ![Lolhit](/forums/images/smilies/more/lolhit.gif)
This school of hard knocks is expensive.
#40
