Thunderbolt IV ICM Conversion
I posted the following at iboats and was referred to this site for potential answer.
I have recently run into the issue of a bad Ignition Control Module on my 1996 5.7L Mercuiser Alpha drive. I have looked for a replacement and see that I can purchase them for around $450 which is so absurd that I can't bring myself to pay it. I have looked at converting to a Delco EST system which can be purchased for around $250 for aftermarket manufacturers on Ebay. I really would like to see if anyone has attempted to install the EST ICM on a thunderbolt distributor. The EST module has the timing curves set for the mercruiser and it is marine rated. I would think that it would only be a matter of making a pigtail to wire it into the system. I do not know if the hall effect sensor would be suitable for input or if the coil would have any issue but otherwise it should work.
I would appreciate any input from others that may have attempted this or have pertinent information on the subject.
Offshoreonly Advertiser
If you are going to use the EST you will need the complete setup using the EST distributor & coil. You also need to hook up the shift interupt
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Hall Effect and Magnetic Trigger both use magnets...but in a different way. I do not see a GM module working in it's place.
You would need a converter of sorts...like some ECU's will have to be flexible with different trigger input types.
Here's a good quick summary:
A magnetic pick up will use two wires, with either a rotating metal component inducing an a.c. voltage (sine wave) in a fixed coil of wire surrounding a magnet (basic electronic ignition pick up) or a moving magnet inducing a voltage in a fixed coil of wire (think of an MSD crank trigger).
A hall effect (three wire) usually uses a blade to change a magnetic field, causing an A.C. voltage which triggers a transistor. This transistor will toggle a supplied voltage (usually 5v on automotive computers) to go from 0v to 5v in a square wave output. A digital (square) signal is more precise because its either on or off, no guesswork.
Thanks for all of the input. I have picked up a module for very little and will do some experimenting. My concern, as SB pointed out, is the signal from the hall sensor vs the signal from the magnetic trigger. I think the hall sensor will give more of a square wave and the magnetic pickup will be more of a spike. I will try to get an EST distributor and compare the signals on an O-scope.
wfo,
Thanks for the offer. You can PM me with the price that you would want for the module. Although I like a good project and it would be helpful to all if we could find a more economical solution to the thunderbolt ICM problem.
wfo,
