Trying to break 100mph with my spare parts. What do you think?
800HP is not alot of power for a forced induction big block. The 900sc, was nothing exotic. A 540 cubic inch, with vintage brodix heads, a low lift solid roller cam, 8:1 static, 1071 blower and lee intercooler. I believe they made 900HP on merc's dyno, with 10lbs of boost. On someone elses dyno, probably a little more. Even if we call them 1.7HP per ci builds....why would that be so insane to think, that a 468, can't make 1.7HP per ci with a blower ?
Well these are dyno numbers with full accessories and a 96 mph straight bottom fountain. All seems about right. It's hard to imagine anyone could put a better combo together than merc.
What does my mph have to do with anything? My non stepped, 10,500 lb Fountain went 96.6. When the boat was brand new, with 420HP 454's, and TRS drives, it went 68-69mph. Its not a race hull, has full cabin with a/c unit, old speedmaster drives, turning 17x28 props to 6200-6300RPM. I can tell you, with an old straight bottom 38 Fever, your aren't getting 96-97mph, with a pair of 650's.
Theres a local guy I know who raced a straight bottom 38 Fever named "juwanna" . Stripped hull for racing. Had 750hp engines, #4 drives. They spent a bunch of time dialing the boat in at lake X. The boat ran 90mph once dialed in, many years ago.
I also have some data from a brand new 1994 Straight Bottom 42 staggered setup, with 6's. Full pleasure boat. Merc 800sc engines, which made i believe 750hp ish at the flywheel. Boat ran 84mph on radar when new. There used to be a race layup 41 Apache around here with merc 800sc engines, that ran pretty strong.
How fast is your race apache with the 950's? What props at what rpm do you turn?
Im not surprised, that your 572, with a much better flowing Dart heads, similar duration but hyd roller cam with 642 lift instead of 560 lift, with a better blower, pair of dominators instead of 700cfm carbs, intercoolers, and an extra 1-2 lbs of boost, plus another half full point of compression, another 800rpm, makes 150hp more than the 800sc station wagon merc engine, using a STD correction factor in dyno trim.
what size are the new carbs joe?
Theres a few full pleasure 41's around here, one has blown 540's, I think it runs 80ish.
You run big chief heads on your N/A engines don't you? What kind of hours do you get out of the valvetrain before freshening?
do you think there would be a power gain or loss with the 1050s?
