Nitrous on 454 mpi mag
Personally I think the hull would be the determining factor. 38 V bottom??? The problem I had was when I got caught for revenge day with empty tanks. Not cool..... plus a couple minutes wot isn't no where near enough especially when you keep pushing someone out further into rougher water.
If you want a drag boat, buy a drag boat.
if you want an offshore boat to go x mph at 5500 rpm, build it to do that. If you build it correctly to do that, it will. if you dont , it wont. If your using nos to make it do something its not built to do, eventually you end up with pieces instead of parts.
Nos has a place at the dragstrip or in little Jimmie's honda car with the coffee can full of bumble bees exhaust so he can make it from traffic light to traffic light in under 10 minutes,
PF Marine
"Nitrous does not blow up engines, people blow up engines!"
http://www.hotrod.com/articles/engin...-305-take-nos/
That being said, if you try to get by without setting the motor up right, or try pushing how much timing you can run or how far you can lean it out, nitrous will ruin parts very quickly......
Also, the only time you see nitrous explosions is generally when something in the valve train breaks.... And in drag racing, it is usually because people can't do a burnout and bang the motor off the rev limiter. Just watched a guy do the exact same thing the other weekend and the whole car almost went up in fire. The other cause of failure is a stuck solenoid from getting junk in the tanks and not being properly filtered.
Engine Masters Ep. 13 Asks: How Much Nitrous Does it Take to Scatter a Stock Engine? - Hot Rod Network
https://www.youtube.com/watch?v=AScojLj139A
