Where to buy Starboard
I plan to replace all of the old plywood on my Formula with Starboard.
I know ZERO about this stuff !! Where to buy and how much does it cost compared to marine plywood?
Ayuh,.... It co$t$ many, Many times more than plywood,....
Are you talkin' 'bout usin' it to replace the plywood in the hull,..??
I donno how well it'll hold/ bond to the fiberglass,...
Boat supply house and my local HOme Depot has small sheets. 4' X 4' there is $40 something bucks. It's also much heavier than plywood. If you're not using for a load bearing structure consider using Structural PVC board. I did so for a bench seat rebuild. I don't know where to source though as the vinyl shop provided the pieces.
http://surfixinc.com/
he's up in here in palm bay,
larry the owner nice guy sells the stuff very reasonable any size you need up to a sheet
cuts w/ circular saw, drills nice, routes nice, not much bonds to it, cleans up nice.
[ATTACH=CONFIG]564821[/ATTACH]
i used it to make the rear seat insert, and a split seat fishin station on my searay.
you can weld starboard you buy starboard rod and a hot air thingy the welds look like they were tigged, or they can be smooth
