New performance engine. Thermostat question >
Old 07-06-2017, 11:30 AM
Received 1,932 Likes on 971 Posts
Originally Posted by Motormanmatt
This is what I think I need
Based on what you have posted, that is correct. That housing has an internal bypass.
Griff is offline
Old 07-06-2017, 12:08 PM
Awesome thanks!
Motormanmatt is offline
Old 07-06-2017, 04:48 PM
Awesome thanks. Does it seem like it would create enough pressure to burst that hose with those outlets kinked off?
Old 07-06-2017, 05:57 PM
Heat, pressure and old hose? It could pop it...
dereknkathy is offline
Old 07-06-2017, 08:29 PM
I hope. We will see after I get what I need.
Old 07-14-2017, 03:17 PM
ONE more question, I ordered the Sierra ss thermostat housing like I pictured. It only came with the blue plastic thermostat sleeve. What are the differences with the white or blue one? Can I just use the blue sleeve?
Old 07-15-2017, 01:08 AM
Just use the blue one. It should be fine.
What connects to the top water 90* water inlet/outlet ????
Griff is offline
Old 07-15-2017, 01:21 AM
Water comes in from port, pumps to starboard side then out the smaller outlets. Is that what your asking?
Old 07-15-2017, 12:37 PM
The top 90* inlet/outlet on the manifold riser???
Griff is offline
