Is it OK to support the motor by the oil pan?
Stop fighting kids.... Thanks to all the gave them input,
My answer was to lower the adjustment on one motor mount and the bell housing and other mount hod it just fine and I was able to do one monut at a time without removing the engine or having to set it on the oil pan.....
i dont think its a good idea to do that even if you dont hurt the oil pan you may stress your pan gasket and create a leak down the road which means the motor will come out at that point I would lift the motor in a safe manor and get er done as us1 has suggested
I’d be a little more worried about placing the weight directly on the bottom of the bilge. It could be fine for all I know but that’s a half ton sitting on just a little bit of core and resin.
