Combustion chamber clean up
My bad ....I thought you bought used heads that were full of carbon.
Just remember everything you take out of the bowl lowers the compression. If BBC you should look un-shrouding the valves.
Just a dremel and sanding drums. You can buy them off amazon in an assorted pack for cheap. I took out 10cc worth of material that dropped compression nearly a full point. I was getting new pistons with a higher dome anyways but blending the chambers can have a big effect on compression. I’d say that I have at least a couple hours into each chamber times 8 and there’s nearly a full work week into just sanding. At the end it would’ve been easier to find some cnc heads.
