Bbc 454 build.
Old 12-27-2018, 02:11 AM
Originally Posted by mike tkach
janiH,you came here looking for advice,i will tell you that the 360 head on a 454 is done at 4500 rpm,i don,t want to see you waste your money soooooo,pay attention,the 360 head is a loozer unless you install a stock 330 hp cam for low end torque but it will still be done at 4500 rpm.you are not the first guy who had visions of 450 hp with that head,that,s all i have to say about it ,sort of seems like you have your mind made up already.
Thanks Mike! My heads should respond well to porting. I am sure you are right about the 4500rpm limit with unported heads. I will post flow data before and after porting, lets see what we can do.
JaniH is offline
Old 12-27-2018, 06:09 AM
chris302's Avatar
Originally Posted by JaniH
all the valvetrain parts would be nice. I think distance between us may be a problem. Roller lifters? Rocker ratio?
Hydraulic flats and i don't want to part out heads
chris302 is offline
Old 12-27-2018, 07:44 AM
Mike, You are correct about the 088 vs. 360. Almost anything is better than Peanut-Butter Heads.
Your expressed thoughts regarding advice are exactly as I was thinking I even went back and re-read post #1. It should be re written asking members for conformation of his plans.
Flow numbers and be darned, flow numbers never moved a boat post the dyno numbers.
This is where I say farewell and good-by to this thread.
GLENAMY 242SS is offline
Old 12-27-2018, 09:25 AM
Sorry to hear that.
JaniH is offline
Old 12-27-2018, 09:32 AM
baja chicken,il bet that thing pulled a load of fat chicks around the lake effortlessy,lol.
Fat chicks, as you put it, tend to have strong oral fixation tendencies that can be quite nice! lol
Baja Rooster is offline
Old 12-27-2018, 10:27 PM
Cool
you can lead a horse to water but you can not make it drink.if the op would listen he would realize that the 360 head won,t do what he wants.any shop worth a crap that has a flow bench already knows the 360,s limits.i will end by saying,good luck and enjoy your 375 hp engine,im out.
mike tkach is offline
Old 12-28-2018, 05:30 AM
add 100hp and then you are close 😉
JaniH is offline
Old 12-28-2018, 08:20 AM
only a twist of the correction factor knob away,,good luck.
sutphen 30 is offline
Old 12-29-2018, 07:31 AM
Default Heads and intake
I have a set of 088-head from my Mercruiser HP500 and also the Dart single plane intake. I live in Stockholm, Sweden so it’s not as far away from you. I could sell heads and intake to you for 800 euro + shipping. Send me an e-mail if you are interested [email protected], I could send you pictures and more info. Maybe I have the GIL exhaust manifolds to sell also
McNick is offline
Old 12-29-2018, 08:12 AM
i had my 330hp 454 built couple years ago and got 430hp at 4700rpm out of it with peanut port heads a small hydraulic roller cam 510 on intake and exhaust with a edlebrock rpm air gap intake and quick fuel 850 carb.the motor was bored .030 over with kb pistons with 9.1 comp.
seaman is offline
