Cam gear for thunderbolt on a 500 EFI cam
I am running cams out of 500EFIs and using thunderbolt distributors that I think came off of mid 90s 350s, I need to know if I need to swap my distributor gear for a bronze gear? I have read that they used crane cams in the blue engines and a steel gear was ok but I do not want to find out the hard way. I would appreciate any info. Thanks
Crane cams that part #'s end in IG have iron gears.
stock dist gear on a 500 efi is iron, at least all the ones Ive seen
i would give crane cams a call but i use a melonized gear with crane hyd roller cams.
I'm building some 454's with 500EFI cams and for $33/melonized gear it's worth the piece of mind changing it.
Is the thunderbolt distributor 0.491" or 0.500"?
