Mufflers for 502 HO ?
Hey everyone... what mufflers would be a good choice for a 502ci HO motor? I like the growl and all but I would rather not hear it!
I am willing to keep a bit more sound for a muffler that reduces noise less but preserves power/efficiency.
I installed Corsa 4 inch mufflers on mine before repowering and liked it. The new motor has more power so now use turn downs so it quite when at the dock
GGB used to make the best marine mufflers, but they stopped making them. I used to run Gibson clamp on, but with 700hp they slow me down so I removed them. I installed the Daytona Sensors ignition which allows me to idle at 650rpm in gear for extended periods which helps with the noise going for cruises down the river. Although I have to warn people when I start it at the dock so they don't get startled and fall in. When you're going fast (70-80) all you hear is wind noise anyway. I have been asking the same question for years and other than GGB everything else will slow you down. Turn downs are an option for some, but I have a big cam and reversion is an issue, so not for me.
92nsx (09-22-2020)
I am currently running a set of IMCO's now with little performance loss. I have a set of Gibson's Bullet 4" clamp on mufflers also but they seemed to loud for me to pass our states 84 db max limit. Id be willing to sell the Gibson's if you what them. 2 sets 4" clamp on
Are there any water box options? or do that cause a lot of performance loss?
What is your states testing protocol? What HP are you pushing and what is your exhaust? I'm pushing 700hp through Lightning headers which are wet and I'm pretty sure I can pass 84db at idle with the Gibson clamp ons.
If your stock about any would do, the stats are from a given distance.
Also if your stock and you want no issues at all, go with turn downs. I'm running 530HP and 3 inch extra up exhaust and don't have issue with reversion
