School me on 1/2 Closed Cooling Systems Please
i changed my motorws over to full closed system, thought i would be in NC, but will be one day,,anyways, bought my heate exchangers thru here used,,i did add to the brackets holding exchangers .think i paid 800 or 100 for both tanks?? my engine shop said was better running closed system.
good luck.......
good luck.......
good luck.......
good luck.......
yes i had to some plumbing tricks with hose...had to cut on going from stack water outlet feeding up to heat exhanger,,had to make it longer
hope this helps....found pumps online from warehouse out of florida,,paid 150 a pump,,saw them listed for 250 on diff sites
i used a johnson crank driven pump...works fine..i guess they were used on volvo motors uses ago
Nice set up. I'm actually just asking about the one hose you had in the pic I quoted. I'm using the factory BBC style circulating pump. I can probably just look at an auto parts store for one that's similar. It's nothing special which is why I don't want to spend $60 on a Merc one just to cut it.
why do u have to cut that hose,,,???
it goes from stock pimp lower outlet,,,up to thermo housing correct???
good luck....
ahhh,,,,,,,i see your heat exchanger sits lower than mine,,,
looks like you could almost cut yours ,,put in a 45 degree elbow in the center ,,so hose mates up to your tanl outlet better.
its all fun..........
but i am at the end of all this fun...
boat is going for sale soon.
good luck........
i added a 8 inch peice to extend my hose,,, i got it from summit...
