power valve
I`ve tried it all, the best fuel curve I got was block off all power valves and tune with jets.
Wanna lean out primary take jet out.
but at the end of the day without a O2 reading he`s pissing in the wind.
I have a Pro Systems 1000CFM 4150 and I have power valves in primary and secondary, although I have restrictors in both. Carb runs great and I get really good fuel economy. Power Valves aren't always bad, if done right. I get 2.5mpg at 60mph all day long.
i love like ...love to add o2 sensors,,,but it would be a big job,,,,and sensors would be in wet exhaust extensions,,,heard suggestion put in 90 degree adapter would solve wet problem...maybe..
i think i am going to start dropping jet size..go run boat mid range,,,,then pull a few plugs..
thanks for all advice....boats runs...just seems to fat...
plugs are always black...
thats some good fuel mileage thisisliving..........what rpm u at running 60...4500???
did u just put on your motors??? i am guessing you had to fine carbs somewhat???
thanks,,,,,,for advice...
The problem with most carbs out of the box is they are designed for cars that have a multi gear transmission and can rev much quicker than in boats. In addition boats are under constant load. I spent years tuning my carb to get it just right and the proper ignition timing and curve are part of that. I have a big cam and in gear at idle I have 2.5" of vacuum. I had to change power valves, jets, accelerator pumps and squirters to get it to run exactly as I wanted. With a big cam and prop it takes longer to get on plane and build rpm's so I needed to extend the accelerator shot and timing to get me to the point I had some air flow to pull fuel. I ended up going to a 50cc on the primary with a .028 squirter on both primary and secondary. I had to use 2.5" power valve and as I stated earlier I have them on both primary and secondary. I bought an Otoscope to help read the plugs. I started the jets on the rich side and kept dropping them down based on the plug reads. Because I have almost no vacuum at idle it was hard to get the initial timing right. I tried special bushings in my MSD distributor to reduce the total advance so I had more initial timing. Then I ran the distributor locked which helped. I finally switched to a Daytona Sensors system that allowed me to create a custom timing curve with added idle control which made a huge difference. Now even without a choke she starts right up and I only need about 30 seconds of warm up and she's good to go. Once it's been started for the day I just give the key a quick hit and it's running. I know EFI can give you better cylinder to cylinder fuel balance. But when I pull my plugs, they are all identical even looking at them through my 10x Otoscope. I think some of that is due to the improved signal I get when I added a 4 hole tapered spacer. That also made a noticeable difference in performance. With motors as in life, everything matters and effects everything else.
wow........alot of info...but i like it...
so do u run the daytona sensor system with your msd distributor????
so u replaced the msd box with the daytona system??
what motor and how big is cam??
thanks for info........
not sure if it was you or someone,,,but it was suggestted to make it a two circuit....
not sure how hard it would be...
but i think a site or two was posted on this..
i did look at one of these sites...wow..
stuff they were talking about changing,,,i didnt even know what it was,,, was over my head..
just did a google,,found a thread on here from 2010...also don terrils speed talk...
thanks info.....
sounds like i should gt new carbs...any suggestions???
