Compression fitting-water pressure gauge
You need the little metal tube the goes in the plastic line. Plastic line will compress without the insert.
https://www.lowes.com/pd/B-K-1-4-in-...ing/1000505345
It is the little tube sticking out. Not needed with copper line but needed with poly.
Need the inner tube piece for larger tubing, 1/8 tubing is not needed
Griff (12-20-2021)
I use 1/8" OD SAE J844 nylon air brake tubing. It's black in color. Got a 50' roll on Amazon 4 years ago.
The supplied fittings from the gauges worked fine with it.
1/8" line can clog pretty easily and make water press readings very sluggish. Some have gone to 1/4". I've had to disconnect both ends and blow out the line at least once a season. I've found sand and rust particles in the line. I keep telling myself I'm going to "upgrade" but haven't done so yet. Something to consider..
F14A water jet (04-10-2024)
I put mine on the intake and a idle I have 5pd at 3200rpm 10 pounds. I have the same gauge you have. I use the line and brass fitting that came with the gauge
I think I understand 10 psi at 3,200 rpms...but 5pd?
Today I had one water pressure gauge go dead after an idle zone. I stopped, put that drive in reverse (in case something got caught on the lower drive unit) for a second and then all was fine?
