Finally Started the LS Swap >
Old 03-05-2022, 10:12 AM
  #31
BEACH PARTY / HOLLOWPOINT
TomZ's Avatar
Received 1,302 Likes on 729 Posts
I have to ask because it’s bothering me; is that bulkhead where the pump is mounted permanent? It looks like it’s bare wood. Once the bilge gets wet in there, that panel is going to be junk in a quick amount of time.
Just an observation.
TomZ is offline
sutphen 30 (03-05-2022)
Old 03-05-2022, 01:36 PM
  #32
yup,,that bare plywood needs to be encapsulated in resin and fiberglass.
sutphen 30 is offline
TomZ (03-05-2022)
Old 03-11-2022, 05:41 AM
  #33
It is bare plywood, but its not actually the bulkhead. For whatever reason it is screwed to the bulkhead, maybe for extra support? I poked around at the actual bulk head and it all seems solid
Ryanw10 is offline
Old 03-11-2022, 06:25 AM
  #34
Are those drywall screws holding it on????
phragle is offline
Old 03-16-2022, 06:10 AM
  #35
Yep...
This project just got a whole lot bigger..
Ryanw10 is offline
Old 03-16-2022, 08:09 AM
  #36
TomZ's Avatar
Ooffff!!
TomZ is offline
Old 03-16-2022, 08:49 AM
  #37
Were doomed!
Wally's Avatar
Received 1,150 Likes on 575 Posts
Originally Posted by Ryanw10
I put it there so I probably will mount it higher yet. My main focus was low as possible to prevent cavitation.
Working with pumps for the last 21yrs i can tell ya those are roller vane impeller type pumps so the only way you will cavitate it is if you have too small of a feed line from the tank to the pump or if the gas level is low enough that you suck air into the pump.... actually there is one more thing...the check valve at the tank fitting outlet. So i wouldn't really worry about placement of the pump. Obviously if the pump is mounted at the top of the engine then it has to work harder to pull the fuel up to itself but for basic installs on a boat i wouldn't worry about it being at the very top of a stringer or even slightly higher
-Wally
Wally is offline
Old 02-05-2023, 03:42 PM
  #38
What flywheel did you use?
PODUNK RACING is offline
