Possible solution for neverending oil temp issues, am I barking up the wrong tree?
I don't get accurate readings since having moved the sender to the thermostat housing awhile back. Am putting on new intake manifolds that have a rear water port so will be relocating them there. Hated having them in the bottom of the block as they were a PITA to remove for winterization and they kept fouling with debris. IIRC when they were in the block I was getting 25 psi with the stats in and around 5 with them out.
On my Scarab I drilled and tapped an 1/8"NPT in fitting under my Thermostat. Probably my favorite spot. I could watch the thermostat open on the gauge.
I would not dump too much water from the back of intake manifold. You could cause a problem some were else. On mine I plugged the A/N fitting and then drilled A 3/16 hole in it. You just want to keep the water moving no steam pockets.
