502 head bolts torque
Round metal flat pieces that go under the bolt head. hope you can see this link
https://www.summitracing.com/parts/ARP-135-3601
and if unable to see, look up ARP 135-3601 you will see the bolt set and washers
OK, SB's last comment was it would be best to use ARP bolts (they come with washers) for your motor.
For the moment pay no attention to the ARP bolt set I previously mentioned
The bolt length in your pics are about 3.5 inch, so both are short bolts, and the torque spec you found for a 502 seems a little light
Do you have 3 different lengths of bolts or just 2 ? Also what year is your motor, or better yet if you have a serial number?
![](https://cimg0.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/20230121_173241_4560c689ffc8e1f40091481010bc1ad6feb47bfc.jpg)
![](https://cimg1.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/20230121_173219_1dd05c995a0188e9f2a83972a4cb1ce877ada5e3.jpg)
![](https://cimg2.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/20230121_173212_97398d67ce4d4ac72231a925f75a2e04bb3487ff.jpg)
![](https://cimg4.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/20230121_173848_47d6bec1f1d4eefd8bc7f3f6c77d88e593938b0e.jpg)
![](https://cimg5.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/20230121_173258_a878190d88fac5e2903968f559bbd42cdea4ab85.jpg)
![](https://cimg7.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/20230121_173246_d2e270345766528b63258f1581ccd021be3ff4ff.jpg)
Two diffrent lenght
If you want to be certain post a picture of the head of the bolt but I am almost certain that those are stock head bolts. I would torque them all to 75 which is the torque spec for the 600hp Mercruiser 502. That is with oil on the threads.
OK, looks like Gen VI block and 088 heads all good.
For factory bolts the torque pattern and spec is in pic below
![](https://cimg9.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/960x720/bbc_torque_5cd692daea7fcf82faf18712bed05dd198c42a76.jpg)
If you go with ARP bolts, then the max torque is 70 FT LB on all. Use same pattern to torque in passes but only go to 70. Bolts listed above is what you would use.
Also the kit comes with 4 short, 4 long and 12 in the middle. The long ones are not much longer then the middle and go only in spots 14 and 15 on each side
Are you reusing bolts or new bolts?
